4 Wheel Alignment Day - More pics added 24/02
Address added below
STS TYRE PROS
Station Road
Wymondham
NR18 0JY
Phone: 01953 603102
Sunday 12th February
Hi All
Just been to see my friendly tyre fitting guys and had a look at their latest high tech alignment gear, Wow they have spent a fortune on the latest gear.
Anyway I asked if they would do a bit of a special for the Owners Club and he was very happy to get involved with this.
So
We need a minimum of 10 Cars (Maximum 20) and he is prepared to open up on a Sunday especially for us so that we can have full use of the facilities.
They can do the 4 wheel alignment to factory settings or your own if you have your own specific requirements they are also prepared to swap wheels and tyres around if required and I am sure he will do something special if anybody needs new rubber.
Just been to see Kieran and he has gone out of his way to make this event great for us.
  1. Free nitrogen fill for all attending, That’s right they will deflate you tyres and refill with Nitrogen for free ( this is worth a fiver on its own)
  2. They are prepared to offer fluid changing on the day for a nominal fee (engine oil, diff oil, Gearbox oil and brake fluid) you will need to provide the oil and filters but they will do the rest.
  3. Bring your own brake pads and they will fit them again for a nominal fee
  4. If you want new tyres then Kieran is offering 35% off all tyres plus a fiver for fitting ( Pirelli P1 185/60 14 £38 + Vat or 195/50 15 £39.24 + Vat) He can get any make but needs to know in advance please.
  5. Tyre changing and wheel swapping
  6. Exhaust Fitting
  7. Free Tea and Coffee
  8. Plus of course the main reason for going the full 4 wheel Geometry setup (Camber, Cast and toe) for £30.00
Basically he has opened the workshop for us and us alone so please support this event.
The Cost
He will charge just £30 for a full 4 wheel alignment and trust me this is a bargain.
When
There are tea and coffe facilities and a nice warm waiting room.
I will have all the details at wednesday’s meet.
Please let me know if you are interested, as I said we need 10 as a minimum.
  1. Ken Ward
  2. Paul 08:30
  3. Malcolm Mazda - 2:30 poss pads & Alignment poss 2nd car
  4. Mal 09:30 ish - Front Discs and Pads & Alignment
  5. John Mellor
  6. Feef
  7. CambsMaz 10:00am slot please Alignment, Gearbox oil & Diff Oil - CANCELLED
  8. Carole with Passport 2:00pm
  9. Steve and Tina 1:00pm
  10. Ray 12:00am
  11. Andrew Scarlett 10:30
  12. Paul - MyLeftFoot 12:30
  13. Peter - White Mk1 Alignment, Brake & Clutch Fluid Change Front and rear discs and pads 08:30
  14. David - BLUE1 Alignment
  15. Betty_Swallocks - Alignment
  16. Ady - Alignment  - CANCELLED
  17. Smiffy - Alignment, Engine Oil, Gearbox oil, diff oil, brake fluid (PM Slot)
  18. GazzaK - MK3.5 - Alignment 12:45ish
  19. ANDY - Alignment
  20. Oberon305 - Alignment + Coilovers
  21. Julian - Alignment
Kevin
 I could be up for this.
Where exactly is the place?  Are passports still required to get across the border into Narfolk?
Sorry it will be in Wymondham, 6 miles south of Norwich on the main A11.
Passports are still required but if you take the Thetford roundabouts fast enough you can time warp through without.
You would be more than welcome, Hope you can make it.
Kevin
Please put me down for this, be great to see it being done, will bring some biscuits alongSmile.
Ken
Biscuits - good idea!
Interesting!
Wymondham is where i bought this car from last Easter! Could be a good excuse to visit the previous owner who is no doubt by now regretting “upgrading” to a Z3 Wink
£30 is a bargain too. Trouble is it would be a 200 mile round trip for me & would be a gamble regarding the weather. Confused
Will they be stocking a few replacement bolts just incase?
 Hi Kev
Please count me in. Will have the 2.5 on the road then and looking for a faster road setting.
Cheers
Paul
Hi Dave
Would be great if you can make it, I know its a bit of a drive but should be a good day out and there is a great pub close by if anyone fancies a nice lunch.
Not sure about the bolt situation, I will raise the question when I see him next week.
Kevim
You’re on the list Paul.
Thanks for your support.
Kevin
Hi Kev
This sounds great - I’ve been trying to get around to doing this for a while on at least one of mine so on proviso the date is ok, count me in!
Shall we all do a few miles together afterwards to check the set ups? :wink:
Oh, and I probably have a few used bolts somewhere too!
Hi Malcolm
That’s great will put you on the list.
It would be great to have a little runout afterwards to see how the cars go with their new setups and of course we are right in the middle of Lotus’s test route so perhaps we could do a few circuits in between of each alignment.
Each car will take approximately 30-40 minutes so this could work very well as we will have 5-6 hours.
If you have some spare bolts that would be great as I am sure there will be a few issues over the day.
Cheers
Kevin
Hi there, could you put me down for this please. I have just had an offer of £60 to have this done elsewhere so it it a bargain.
Mal.
On the list Mal, Thanks for supporting this event.
Hello All,
Please excuse my ignorance but what exactly is this 4 wheel alignment all about and how will my car benefit? I’m in so long as my baby will be all the better for it…and Mrs MyLeftFoot gives me a pass…Stick Tongue Out
Paul.
Hi Paul
The MX5 benefits from having a fully adjustable chassis, this means the Camber, Castor, toe in and toe out angles can all be adjusted to suit your own driving style. Obviously Mazda set these at the factory to suit the majority of usage which is road use. You can change these angles to improve the handling to suit say track use or dast road use.
Over the years these adjustments can get knocked out of position through kerbs and potholes etc which will of course upset the handling of the car.
What we are doing on this day is to make sure the angles are all correct and make any adjustments as neccessary. Some people will be quite happy to have a standard factory set up and others may have their own requirements.
£30 is a bargain for this and the Guy has really done me a favour. I will try and take some pictures next week of the set up there so you can see how much they have invested.
If you are still up for this then let me know and I will add you to the list.
Regards
Kevin
Thanks Kevin!
Wow I never knew there was so much that could be done to these great cars! I will work on the Missus to get a pass. I see that there is a minimum requirement for 10 cars but is there a maximum? I’d say yes now but don’t want to mess people about if I’m not sure I can make it as yet…
Paul.
 Also worth mentioning that having everything aligned properly will prolong your tyre life.
Hi Paul
I would have thought they could do about 14 in the day he just said to open up especially for us he would need at least 10.
Kevin
Good point Dave although I am not sure it will cure my oversteer problem but I think that’s more to do with the nut behind the wheel.
