Brian,
From ‘flyin miata’ (https://www.flyinmiata.com/tech/alignment.php)
RECOMMENDED ALIGNMENT NUMBERS
NA/NB/NC
A good alignment makes a huge difference to car handling. The standard numbers from Mazda are fairly vague and don't necessarily flatter the Miata. A precision alignment can make even a standard Miata more fun to drive.
These are the numbers that we use at Flyin’ Miata on the NA/NB/NC Miata. They work well for cars fitted with our suspension kits or stock setups. There is no odd tire wear. Racers will want to vary their setup based on their particular needs of course. If you take your car to an alignment shop, ask them to come as close as possible to these settings. For a full discussion of what these numbers mean, you can read Miata Performance Projects.
It’s possible that not all cars will be able to reach these numbers. If this is the case, please call our tech line (1 970 464 5600) and our techs will be able to advise you.
Front
Caster: 5.0 degrees
Camber: 1.0 degrees negative
Toe-in: 1/16", 0.15° or 9 arcminutes total (1/32", 0.075° or 4.5 minutes per side)
Rear
Camber: 1.5 degrees negative
ND
The ND has a very different suspension design, and combined with the electrically assisted steering, demands different numbers. These are the numbers we use on our cars, and they've shown no unusual wear and have pulled over 1.05g on the skidpad.
Front
Caster: 8.0 degrees (basically, as much as possible)
Camber: 1.8 degrees negative (again, as much as possible)
Rear
Camber: 1.8 degrees negative (matching the front)
