Have tested my ABS fault codes on my Mk2.5 and it indicates code 51 - valve relay failure.
Where is the valve relay? I can’t see where on earth it can be.
The relay is part of the ABS module. I would recommend an independent rest to verify your fault code as these modules are horrendously expensive. If the module is faulty I am told they can be repaired/rebuilt at around the £350 mark plus fitting. Try www.bba-reman.com www.ecutesting.com www.sinspeed.co.uk I have no personal experience of these companies but I have read in the press of the problems VW are having with ABS modules. I read that they were being replaced at a cost of around £1500! now I believe they are being repaired.
Regards Geoff Peace
Thanks Geoff - I managed to get a used module from eBay for 40 quid which solved the problem. Cheered me up no end after reading the horror of what it could have cost!
Cheers
Mark
