- My model of MX-5 is: 04 NBFL SVT
- I’m based near: Leeds
- I’m looking for technical help or recommendations on: Removing the cat section of my exhaust
Evening all.
Plenty of cat theft around, so I’m getting ahead of the worry and removing it myself. I’ve been quoted £780 for the cat, (Platinum Group Metals Recycling ltd - Home | Facebook), and have lined up a stainless replacement for only £130, as I’m not bothered about it being a sports cat, (MAZDA MX5 1.8 11/00-10/05 Catalytic Converter MA6073T).
More interested in it continuing to pass an MOT and that £650 difference will come in handy for tidying up the old girl!
My trouble is, I’m not as uninhibited as those who go at the car with an angle grinder as I quite like it and want to continue to enjoy it afterwards. As a result, I’m struggling with various partially concealed nuts and bolts.
While I’ve made reasonable initial progress, having removed the bracing, some form of under tray and the four nuts holding both ends to the rest of the pipe, I’m stuck with what appears to be a bracket from the pipe to the side of the gearbox.
What would happen if I went at the two larger bolts into the gearbox? Bad things?
The single, small nut on the back of the gearbox bracket looks like it would normally be the one to try to remove but, as it’s been baked by the heat from the cat for 15 years, it’s in bad shape! It’s also quite awkward to get a socket over it…
Next question is how to remove what I think is the O2 sensor attached with a lead to the side of the pipe. It’s quite awkward to get at! Is that easier to leave until the pipe is removed, then go at it?
Also, are the two bolts at the rear end of the section captive, or should I be able to remove them? The nuts have come off alright with a bit of effort, but the bolts seem fixed. Isatright?
Finally, do I need to remove, or simply loosen, the centre pipe and silencer in order to free up the cat section?
- How to remove pipes from gearbox brace?
- How to remove O2 sensor as it’s awkwardly placed?
- Are the bolts captive on the rear of this section?
- How much exhaust system do I need to remove, to get this section out?
