I’m looking for technical help or recommendations on: issues starting in the mornings
in the mornings it will just not catch or fire.
i have replaced all of the following items.
Air filter (pipercross)
New Panasonic battery
Fuel filter
Spark plugs
HT Leads
Coil pack (used of eBay)
Cam sensor
Air temp sensor (one that’s goes into air box)
Crank sensor.
Fuel treatment
coolant Temp Sensor (rear of engine)
02 Sensor (oxygen sensor )
if its cold or wet it will not fire up,
i have just tried again this morning as i changed the o2 sensor yesterday after using the dignotic LED to come up with error code 15 oxygen sensor (output too low), fired up first time, but over night it rained.
there is no water i can see anywhere.
i dont know what else i can try. hopeing someon here could advice what to try.
Hi
You have one of the worst types of problems to solve, intermittent ones!
From your description of what has been done, and that damp may be a cause, I would check the ECU connectors.
The ECU lives under a plate in the passenger foot well, you need to lift the carpet and possibly drill out a few security screws.
Look for signs of water ingress and check all the connectors for corrosion, if there are signs you may have to open up the ECU and check inside.
If you find nothing then the problem is possibly elsewhere, but this is not an uncommon issue.
I’ve read in the past about earthing problems from battery to chassis causing starting, electrical issues etc. Worth checking all earth straps for good contact.
i have done the one on the top of engin near the injector rail / intake
i have also done the strap the goes from engin to the passenger side of the body under the washer bottle area
Someone will correct me if wrong. The battery connection from the boot area to an earthing point at the rear chassis.
It’s been a while since I’ve owned a Mk1/Mk2 so precisely where I’m unsure now.
My ECU cover plate looked a lot worse than than when my car ‘flooded’.
The issue was blocked drain tube. I have since relocated the ECU behind the glove box and have an as new cover from Mazdadudes I’m planning to fit when it stops raining
so seems that the broken earth hasnt solved my issues
however i have pin pointed it down to the be the cooleant Temp sensor,
if it unplug it ans crank the engine it starts, i can the plug it in whilst its running no issues,
however if i dont disconnect it before trying to start from cold / over night no joys.
now i have replaced this part allready with an offical mazda part. is it worth checking the earth on this cable? as 3x wires go to the plug the onther one a Earth.
