- My model of MX-5 is: 1996 UK 1.8 iS
- I’m based near: Guildford
- I’m looking for technical help or recommendations on: Airbag
Sorry missed off the question…
The car had been in a cartoon for 2 weeks, came out the other day and airbag light on permanently. Quick trip to local garage, they did not know so they got a auto electrician put to take a look. They said that the airbag module had failed. Sourced another one online, stripped out dash to replace it, same issue.
Help any ideas?
Thank you
Have you seen the Air bag flash code chart in the member download section? Is yours a later type car? Where did the SAS unit come from?
Yes I had seen the air bag codes from the download section and it implies a problem with the sas unit - part number N034-57-K3XC.
The old part came from MX5Bitz and Rob from there has been very helpful and also said if it did not solve the issue, then I can return it.
