Hi folks, for those looking for a cheap and good looking (my opinion) centre console armrest cover for the NA…ther’s this (Universal) armrest cover from Ali express costing 3,95 eur. While searching their site i found their armrest dimensions close enough to the NA centre console armrest cover. So i took my chance on it and …if not satisfied i would survive this as the cost is ridicoulisly cheap.
The cover has indeed the right measure and holds with two rubber straps which is fine but it “slides” a bit with your arm on it and the rear strap is not tied properly (rear hinge) and this brings the cover slightly out of shape. So i glued it and now and that fixes it the proper way.Sideways it’s a tight fit and the front/back of the cover is slightly longer as the cover and that is perfect as it covers the apearant opening seams on the cover.
Firstly , i was thinking about adding some foam but that would compromise the fit (sideways ) leaving some space between the cover and the console…
Uploading: 20220403_132803.jpg…
