- My model of MX-5 is: nc2
Was getting a track day setup done today, car was way out and had almost zero front camber.
Wasn’t able to quite achieve the targets I wanted:
Front Left -2.3 degrees camber -0 degrees 1 minute toe out
Front right -1.5 degrees camber -0 degrees 1 minute toe out
Caster on both sides 5.38
Rear Left -2.5 with 0 degrees 2 minutes toe in
Rear Right -2.5 with 0 degrees 3 minutes toe in
Total tear toe 5 minutes in
Total front toe -2 minutes out
So issues are:
Not enough front camber adjustment and the front right won’t go anywhere near, bolt is maxed out to get that I got.
Could knackered lower arm bushings cause the lack of adjustment? What else could be causing an inability to get anywhere near -2.5 on front
We ran out of time or I’d have asked to take some of the rear camber out, so it’ll stay like this for now.
But interested in suggestions about fixing the front up. New arms? New bushings? New adjustment bolts?
