Hi guys,
Im just after a little advice, last night driving some from work my Mk1 conked out on me twice at low revs. At the time I thought it could have been a fuel pressure issue…not that there was a splutter or anything I was just very low of fuel
I managed to get fuelled up, got her home without any more issues though I did sit a traffic light holding higher revs when I had to stop. I sat on the drive when I was at home. The car was idling and reving ok so I went inside feeling it was likely to do with Fuel.
So a few hours later, after the engine had cooled, my curiosity got the better of me so I went and started the car. Started straight away per usual, I let the idle settle, revved her a couple of times, no issue. Switched the side light on to light the instrument panel, no issue. When I asked the the headlights, everything dimmed considerably, the idle started to move a little but when I blipped the throttle the was a horrible squeal from the engine bay.
I went under the bonnet and revved the engine and the horrible squeeling and sqraunching sound was definately coming from the front the of the engine. Alternator and belt are probably on the out right?
My question is though, surely the alternator is working all the time to charge the battery? Turning the lights on doesnt add load to the alternator does it?
If I can get home before it gets dark I will attempt to get a vid of the situation just for clarification!
Cheers for the help in advance!
