- My model of MX-5 is: 2004 1.8 Sport NBFL
- I’m based near: Glasgow
- I’m looking for technical help or recommendations on: Alternator
This is probably an easy one for most of you, but I’m needing better knowledge than my guesswork.
After a good, fast run out at the weekend, the alternator has started making a squeaking noise which wasn’t there before. On the drive to and from work on Monday, this turned into a battery warning light every time I stopped at traffic lights, along with the squeaking stopping.
Keeping the engine above 3,000 rpm the alternator charges ok, if it drops below ~2,500 rpm even when moving the battery light comes on again.
Aftermarket stereo has a useful function which shows the battery voltage, so I can see I’m getting ~14.8V when it’s charging ok and it drops to 12V and below when the battery light comes on. Alternator belt seems to be spinning ok whether the alternator is squeaking/charging or quiet/not charging.
Video of the squeak: https://youtu.be/6WLikcUkyfE
Is tightening/replacing the alternator belt likely to help here, or am I looking at replacing the alternator? Recommendations of any other checks I can carry out?
Thanks in advance
