Android head unit for MK2.5 NB
I am thinking about fitting an Android head unit to my NB, there seems to be a lot out there, I am thinking of a budget of upto £150 and looking for any advice on what decent units I should consider?
I fitted an Xtrons TS708L unit in my NC, very pleased with it, no CD/DVD drive though, didn’t bother me as all my music is on an SD card, I found it on offer for £129
Thanks, Xtron looks good and running Android 8. My main use would be sat nav using waze, maybe some music eg spotify possible radio.
Fitted an x trons to my mk2. Its very good for the money. You will also need to get a double din fascia plate & a wiring harness adaptor. I had to swap over the permanent & switched lives on mine for it to work properly. Also the electric areal doesn’t come down for about 5 mins after it is switched off for some reason.
Sounds like Xtron is the way to go, where do I get a double din facia? I was thinking the it would be a straight fit replacing the current double din (apart from the wiring of course).
Oops clicked post twice
The OE Mazda one looks like a double din but it isn’t. You will need a double din cage for the new one to slide into. I just got mine from halfords.
Thanks, just the cage then, I was expecting to have to get one, not got the old one out yet.
Do you know if the Xtrons will work with the Android Auto app?
Sorry, I have no idea.
