Annoying noise from between the seats
Hi all
 I have a 2007 Mk3 and whenever I pass over the smallest of bumps I get this squeeking noise from the compartment between the seats.  I also makes the same noise if the pressure is applied to the same compartment between the seats.  I tried to follow to figure exactly from where the noise is coming from but to no avail.  If anyone could help me out cos its quite annoying
 Chris
2007 Mk3 1.8
I have far more squeaks and vibrations from the interior of my Mk3 than I did on my Mk1s - tut tut what has happened to build quality? Do you have leather seats? Are you sure it isn’t the seatbelt catch or the console squeaking against your seat base? Mine does that.
There is a technical bulletin about noise form the cubby box latch area between the seats. Visit your dealer they should sort it under warranty.
