Evening all
Need some advice before I waste more money! My 2009 2,0 Sport Tech Roadster has BBR’s stage 2 turbo and had their Koni lowered suspension. However I kept catching the underside of the car on things - not helped by living down a poorly maintained, heavily cambered private lane. Ride height was 335mm front and 325mm rear (I think the rear springs had sagged in the 2.5 years since I fitted them). So I swapped the BBR springs for a set of Eibachs, but this has made it even worse - my ride height is now 330mm both front and rear.
I believe standard ride height is 350mm, so I guess I’m looking for an uprated setup which will cope with the power but with a ride height around 345mm to 350mm. Read lots of good reviews of the MeisterR CRD setup, but what is the maximum ride height these can be set to? Also I don’t want to ruin the ride - I’m the wrong side of 50!
Dave
