Anyone running a Fast Forward supercharger?
Yes he uses the standard power cards supplied with the kit. Power wise there is not much difference between my kit and his, although i have more potential for extra power and improved mapping that i can see on screen within Tunerstudio.
With the Megasquirt system you can also use “Autotune” if you fit a wide=band sensor. this gets your tune about 95% of the way very easily. Saving on expensive rolling road time.
Drew the other FFS supercharger installation uses the flexible pipe currently, but he has seen mine and is going to fabricate his own version in a similar fashion.
He has used the flexible pipe on both the coldside and hotside positions.
I think he is also considering the Megasquirt route as well.
You can buy the kit at a cheaper price without engine management and now there are 2 or 3 aftermarket ECU’s which can control the VVT, without and additional box or software.
Chris
