Hey! first post in the section, apart from the faq’s.
So, has anyone tried using an AC condenser as the radiator for a chargecooler system?
Or failing that, has anyone who’s removed an AC system got any recollection of roughly what size the inlet piping is on the condenser? I assume it’ll be pretty restricted compared to the 19mm hose typically used for chargecooler heat exchangers and pumps. Maybe not completely out of the question for non-track use, though.
I guess I’d use one of those ubiquitous Bosch pumps, used as auxiliary coolant pumps on lots of VWs and other cars. (Nearly got one dirt cheap on eBay the other week - bloke posted it as an “Auxhillary” pump, so hardly anyone found it and bid.) I can probably cobble something together to raise the drive volts as the chargecooler heats up.
