I cannot find the Ariel Transmitter that’s fitted to
my MX5 MK4 2018 does anyone know where it is located on the vehicle.
What do you mean by aerial transmitter?
Not sure what you mean either but if you mean the ‘antenna amplifier’ it is integrated within the rod assembly.
Have a look here Manual pages - MX5 Manual | Mazda MX5 (Mk4) 2015+ and everything is detailed for you.
If this is not what you are after a search of the manual should find what you are after.
Thank you for replying it’s the receiver, transmitter that’s in the car not the key fob
Roy
Sorry may not be explaining it very well
It’s the receiver that is some where in the car that recognises the key fob , to enable you to start the engine.
Your assistance greatly appreciated
Roy
It is all in the manual that I sent you a link to, as a hint look for ‘KEYLESS ANTENNA REMOVAL/INSTALLATION’
If that is not it just keep looking and you will find.
It is worth putting the link in your ‘favourites’ folder as you will be able to find most of the information you will ever need.
Many thanks I give it a try , certainly I will dave the information.
Many thanks
Roy
