- My model of MX-5 is: NC 3.5
- I’m based near: Chelmsford
- I’m looking for technical help or recommendations on: I’m fitting the Atoto A6 head unit and wondered if the GPS receiver could be mounted to the underside of the dash top. I don’t want it visible
I have mine just to the left of the speaker grill in the dash.
It is wedged between the plastic dash and the metal bar below it.
Don’t forget it should be pointing UP ( the flat surface should be facing down )
Glad you said which way up as I would have stuck the flat side to the underside of the dash
