I would suggest this has been successfully fitted to a MK2 car but as you say is too long to fit to the MK1.
I have encountered similar aerials on MK2 cars before.
Will your MK1 facilitate the Mazda aerial? I ask because early cars, 1992 and before will not without radical mods. You can spot early types because the aerial base fitting is quite different(unlike MX5Parts photos) and there is a metal support welding to the inside of the wing below the hole for the aerial.
If so I strongly recommend a good secondhand Mazda MK1 aerial - these really are an excellent part.
Its a 1993; the factory power aerial is knackered (motor was dead, in the tip). 20-25 year old factory power aerials regularly sell for £70-100. Too much for this car, so I have just fitted a rubber aerial. Looks fine.
Factory power aerials were fitted from Sept. 1991. Before that, there was a dealer fit semi-automatic power antenna for Japan only.
I have handled well over 100 MK1 and MK2 original Mazda electric aerials.
The MK1 aerial rather like the car suffers less corrosion and other issues than the MK2. MK2 aerial is flimsy in comparison with a thinner and longer mast that causes far more problems.
Only encountered one MK1 aerial with a broken motor - they are usually bullet proof with a snapped mast worm being the main repair requirement.
Most of the MK1 aerials I handle are dated 1992 - 1996 with no issue. All I have to do is strip them, clean and grease.
These regularly sell in as removed order on ebay for £30 - £50, so you can buy one cheap, do what I do with it and away you go. I just sold one on ebay for £73.99 with a new mast and a three month guarantee - this is at the top end of price to pay for these. This was a 1994 aerial and will no doubt be worth the same sort of money when the car it has been fitted to has been scrapped.
You pay your money you make your choice but don’t buy a cheap aftermarket MK2 aerial to fit to a MK1. Aside from the physical impossibility, the wiring is completely different. Yes, it can be bodged in electrically but what is the point?
