Automatic Experiances
Hello everyone,
Newbie here.
Im not wanting to start an Auto V Manual conversation, I have to have an auto due to a mild disability. A manual is simply not an option for me.
Ive posted in the “wanted section” and you will see I’ve had some great responses already.
So… what are your MX5 auto Experiances?
Im after a classic car feel so steering towards a 1.8 NA or NB, am I thinking right?
Would a newer car still retain the classic car ownership experiance.
It will be a third car for me and I’m wanting to Eurotour to The Alps in 2019.
this looks like a jap market approx. yr 2000 Mazda Roadster VS and with a hardtop. Says it needs an engine, plenty of people on here who can fix that. Check for rust in the front chassis and the sills
Hi
I have had a 1992 mk1 1.6 Auto for 4 years, as a weekend and holiday car
went for auto as I have had a bad back
I am sure the manual is better, but I thoroughly enjoy driving it hence owning it so long
we have been to the Alps and driven up the Petite St Bernard and back through Germany and the black Forest
we have also toured Holland & North Germany
good luck, you will not regret it
The first car I imported from Japan was a 1990 auto. It was alright but nothing like a manual to drive. I would suggest you drive one to see if it is the car for you. However there are many automatic SLK’s and BMW Z4’s which might attract you. Much bigger than an MX5 and a bit thirstier but the higher power versions overcome the limitations of an automatic box. The SLK is a bit easier to get in and out of.
Barclayboy,
Manual or Auto? There’s a question. Auto’s are marmite. I happen to love mine to bits. I also love driving the Sport …for different reasons and when my spine says it’;s OK.
We have owned 2x5’s for nigh on 15 years, a 2002 Sport and a '93 Mk1 Auto.
I need an auto for intermittent spine issues following being written off many years back by a drunk driver.
It’s done 80,000 odd miles in my hands as a daily commuter in thick traffic, fun days, and a few years back it did 2,026 from the north of Scotland to Portsmouth in 6 days flat, and I stepped out of it fresh as a daisy back home. It was brilliant and absorbed all the punishment I was obliged to cane it with given the time-trial element of what I was up to.
It had been pre-event serviced/ prepared mind you, but still …it only needed a light bulb.
Comparision is very subjective between the two. The Sport is “the better car” on several levels. NVH, speed, and chassis trump the Mk1 although the Mk1 still sits on it’s original stuff which is due to be renewed during it’s Spring rebuild/rot fix. It’s a rarer example, it’s served me well over the years, and it’s staying with me for retirement fun days.
Driving the auto has both limitations and benefits for me anyway.
It won’t win any “first 2 seconds” of a traffic light drag, but once wound up goes like a ruddy stabbed rat mid-range if needs be.
It wont, being a Roadster, change out of 2 gear until the water temp takes it off ECU enrichment, making it a lousy cold weather short trip car.
Something to do with Japanese emissions I think.
3k rpm at 70mph. Very relaxed.
Kickdown gives more than ample safety performance to get out the way of trucks etc.
I’d rather not mention the change-up velocities with your right foot buried…suffice to say they may surprise.
It’s a real boon around town though, a great point & squirt machine, and a great long distance cruiser if the 'box is left to it’s devices. If you need to go hooning in quiet back roads, pop it into S and you have a two-gear go-cart. But , we are all grown-ups and don’t do things like that…
I cannot speak for later models, but it’s a piece of cake once you learn the foibles to use the box in conjunction with brakes to add engine braking when setting up for the next bend by depressing the Hold button. The so-called lack of engine braking is present if you can’t be bothered.
Bad weather eg ice & snow? Provided tyres are fine, no worries. It’s a piece of cake to let the torque feed in gently from tick-over to get you going despite the open diff.
Often times “we” got to the office when others in “superior” vehicles called in for a duvet day. Wimps. That used to cause some hilarity and embarrassments, but then I’ve spent a life-time driving commercially in the worst conditions needing snow-ploughs since the 70’s so it’s pretty much second nature.
It’s vital the ensure your braking system is bang on, as it does need more of a shove then a manual, but I’ve never been able to fade them even on a couple of track days.
It will also be absolutely vital to ensure all the fluids are renewed for your proposed trips eg coolant, auto ATF, and brake fluid.
If yours does not come with a mesh radiator guard, fit one. There are tons to pick from.
Not for everyone, but those like me are grateful they exist. I would say, contrary to common perceptions from those who have either never been in one, never mind driven one, you have a lot more control than imagined…once you learn how to show it who is boss and don’t mind visiting the Esso shop a bit more than you’d prefer.
In my long ownership & experiences, living with an auto is easy and rewarding. Look after it and it will look after you giving you years of fun through all weathers thick and thin.
Hiya, this brace of 5’s used to be in my ownership. The one in the foreground is a 1.6 auto. Very contrasting with the other which was heavily modified, including a supercharger and was manual.
The autobox was a very much more relaxed drive but was a great car. On country twisty B roads, I used to hold it in 2nd and found this to be perfect, engine braking was there, good acceleration through the corners and exiting from same. On tours/long drives, pop it onto O/D and just get on with it. Think about it, apart from the transmission ( and a slightly detuned engine) it’s a 5, so handling remains excellent. Agree with all the scottishfiver says, different car yo a manual but equally enjoyable. The box is very, very strong, was fitted into London taxi’s at one point and light commercials in Japan. They are old fashioned and not quite the same as a modern box but if you’re after a “classic” drive, what more could you ask for.
The red car looks stunning.
This will be a third (fun car) for me and to share with my son…it has to be an auto for the reasons I said in my first post.
My second car is a Boxster S and it’s a joy, perhaps to quick for the road.
im really after that raw sports car feel, like an old MG or something, but it has to be an auto.
Mnay thanks for all the posts so far they are very useful
Hi - not sure if you have sourced an auto but I’ve just posted one for sale in the for sale forum.
2001 Auto 28,000 miles - absolutely mint.
I love autos! - I’d never go back to manual and the MX5 auto is really responsive!
Just sent a PM
I have a mk3 and not had experience with a NA or NB but coming from a normal car it felt very different to any modern car I have driven including a drop top audi. To me it feels much more like a classic car. It has all the simplicity that you can manage in a 21st century car without adding anything that isn’t needed. The powershift version is supposed to be very good and take very little away from the driving experience of the manual as you can still swap cogs with the gearstick or the paddle shifters
My wife talked her boss into letting her have an NC (mk.3) as her company-car back in 2011, with a 2.0L engine, a PRHT, and a Powershift transmission.  It was a fabulous car, our first MX-5, and we kept it as our only means of transport for over four years.
When the MX-5 company-car’s lease / hire period was over, and because we didn’t like the ND shape, we chose a VW Scirocco as a replacement, but we missed having the 5 so much, that we bought another NC to have as a second car.  This one is a manual, as we couldn’t find an automatic at the time - they are pretty rare.
Not exactly being a ‘boy racer’ these days, I like the easier drive of the auto box - each to his own.
I bought my 2010 MX5 2.0 Sport Powershift roadster in October and have to say I love the car and the auto box. It is great fun to drive and as it my all year round daily driver I get to have fun driving it most days. I was lucky enough to find an automatic roadster but had to travel 250 miles for it but it was worth every mile.
Thanks for all the feedback, it’s very usefulL ???
Had an 1993 import, they are nice to drive but the MPG as around 20 mpg
That’s about right in congested traffic. Real life country roads giving a bit of beans around 26/28mpg,
So saying, our 2002 Sport did about the same on it’s short urban commutes to school and back…given it barely got off the warm-up.
