I’m looking for technical help or recommendations on: __Fitting a Aux Jack.
I would like to fit an Aux Jack to my radio. I have looked on Youtube and it looks simple but when I took a look on my car there is already a plug in the place where the Jack should go. Arrowed on the picture. What is this plug for?
Help please.
I had a connector there too on my 07 PRHT. It was for the optional Mazda iPod connection kit, in my case. I just removed it completely when I found the other end hiding behind the glovebox. There could be other options fitted to that socket, like an aftermarket bluetooth or aux/bluetooth. BTW mine was not the Bose headunit, I don’t know if that has something else fitted there.
If the radio is the standard unit, then that cable is for a CD multi changer, which doesn’t come fitted as standard.
If you have a plug in there already, then I’m guessing that you have a multi changer, or someone fitted a kit before hand, maube a parrot kit, or something along those lines.
A standard install wouldn’t have anything in that socket.
