Best value silicon grease to lubricate roof seals on NC retractable roof
Hi I am new to the forum and I am trying to address wet carpet under passenger seat. Have tackled front scuttle plate issues and cleaned rear drain tubes with trombone brush. I want to clean and refurb roof seals. Can anyone recommends a good value silicone grease product?
See the second pic in my post from 2020, it shows one of the two pipes from the PRHT’s equivalent to the ST Rain Rail.
These pipes sometimes work free, and then rain can be dumped in the wrong place to find its way out of the car, especially if the car is on a slope.
Thanks for the advice . Much appreciated. Will check attachment of rear tubes again and ensure that they are securely fitted.
For rubber seal treatment try “gummi pflege rubber care”
This is what I use as well.
Yep, i use it as well. Have done for a few years on the MK1
Many thanks
Much appreciated.
Silicone grease may attract gritty particles which could wear the seals. I use this:
Many thanks for the tip. Much appreciated.
