I have recently bought a 1.8 mk3 07 plate 68k, unfortunately when driving there was a rattle that then got very loud tinny knocking noise. The car was taken to a garage, sump removed and cyl 2 big end journal has failed, crank scored and con rod scored too, I have looked into possible solutions and they are expensive. but am looking for advice really any thoughts are more than welcome.
Sorry to hear that. These modern engines are not easily re-buildable in the way that Mk1/2 engines were with a crank re-grind and new shells etc. It would probably be possible to order a new crank and bearing assembly but probably more practical to source a good used engine from a supplier like Autolink.
The problem you have with the early MK3 is well known and Mazda have produced a lengthy technical bulletin about it.
Unlike the MK1 and MK2 cars where a lot have been scrapped and you can pick them up for a reasonable price.
The age of the NC cars is still young, therefore less than 10 years and only accident damaged cars are at the scrap yards.
There are a small number of engine failures but that small number is around the same as the number of accident damaged cars.
Therefore there is no ready stock of good used engines to reduce the price.
OTOH there are plenty of early car engines and gearboxes waiting to be sold.
My guess and I could be wrong is you will be nearer £1,600 for an engine but I hope less.
Reports from the states is that while the components of the engines changed during 06,07 and 08 prior to the face lift there was no good year and Mazda would replace with components from different years!
