blocked CAT
Hi does anybody know the symptoms of having a blocked CAT???Ive been loseing power and feel as if the engine is spluttering for short periods???
What age car?
1990 import
Doesn’t need a cat, but check the front pulley it is more likely to be the crank pulley coming loose see
 http://mx5oc.co.uk/forum/forums/t/228.aspx
 http://www.miata.net/garage/hsue/crank/loctite_1.htm
 Might be something less serious.  Could just be misfire due to the plug leads breaking down - that’s quite a common problem.
not been able to get spark plugs out yet but the leads look allmost brand new!covered the engine and the airflow metre with a sheet last night and it drove like a dream this morning!!!
sounds like leads first then [:D]
