Blyton Park 23rd March
Right chaps, if you come on Sunday, you will be the first drivers on a commercial track day to drive on this tarmac.
So if you want some of this, in Richard’s own words,
To talk you through it: from the start anti-clockwise, you accelerate hard down a familiar straight, but at the bottom you need to brake harder to turn through “Chapmans “ (I am a Lotus owner!!) “ K7” is tight and will need 2nd gear before accelerating hard through “Trubshaws” in third. I think “Curva Grande” is a real challenge as the car gets very loaded up and the corner is a tightening radius without any very obvious reference points. Just when you think you may be in the right place, “The Wiggler” is upon you and with the car heading to the right, you need to turn sharp left. At last, you get a bit of a rest on the familiar drag up to “Bishops” followed by the delights of “Bunga-Bunga”. But then the familiarity stops as you stay on the power through “Port Vite” with a very hefty shove on the anchors required for “Ushers 2”. It’s almost a relief that “Twickers” is the same ……but you are now on another lap and “Curva Grande” is only half a mile away.
Then book HERE
Got some instruction to give in a DB6. I know it’s not quite James Bond or the Italian Job, but Matt Munro will still be going in my head. :slight_smile:
April 12th circuit ?
Epic new circuit layout! Couldn’t keep Rob Boston off it!
