Bolt Inside Trim
Hi,
I’m new to this so please bear with me;
Last year I exchanged a Mk.2 which we had enjoyed for 10 years for a Mk.3 which soon developed a maddening rattle. I thought it was behind the dash, so I removed the radio (great fun! Thank god for the internet!) but found nothing. I took my mechanically savvy neighbour out for a drive, & he reckoned it was coming from inside the trim above the windscreen. We removed the hood locks etc. but realised that removing this trim would not be easy;  however we managed to lever the front of the trim down, & saw (& extracted) a torx bolt, the same as those holding the hood locators.  Problem solved.
Question; has anyone ever heard of this before, & does anyone have any theories as to how it could possibly have got there?  I don’t.  Thanks for any answers.
I’ve come across it before, has it not fallen out from one of your roof catches or the centre catch?
Thanks Robbie.
How could it fall upwards into a sealed space?  It was in the trim above the roof catches, that’s the mystery!
Check the centre catch for a missing screw, that attaches above the trim doesn’t it?
Hmmm, I’ll have a look.
Thanks.
Hi again,
There are 3 hood locating points above the windscreen. I removed the 2 outer ones yesterday in at attempt to get at the space above the plastic trim. All 4 bolts were present, & there is no gap in that area to access the space where we eventually found the bolt.
The centre locating point is different; there are no visible bolts, & I could not see how to remove it, so I cant tell if 1) there is a bolt missing, or 2) there is a big enough gap there for a bolt to get behind the trim.
Can you tell me how this centre locating point is attached, & how to get at whatever holds it in place?
Maybe it has been removed at some point, & a bolt was lost behind the trim.
Thanks for your help & interest.
If you’ve not seen this already, have a look around it all, might be useful to keep it on your desktop.
http://www.mellens.net/mazda/Mazda-Miata-2006-2007/index.html
What about an extra bolt left in at the factory.
Is the windscreen original? Possible someone had loosened the catch, shoved the screw there for convenience, forgot about it, and missing screw was later replaced. And yes, probably the catch and trim doesn’t need to be disturbed, but a lot of these so-called professional mechanics can be idiots.
Also, there is an overhead light here, and the trim needs to be disturbed if any repairs are needed.
Thanks;  my computer refused to download this link?
Hi,
I wondered about that, but my wife was adamant there was no rattle when she drove it home last year, so why now?
Hi,
Yes, I wondered about that, but my wife was adamant it wasn’t rattling around when she drove it home last year, so why now?
Chris
Hi Saz,
Yes, I guess that’s possible.  I will have to accept that I will probably never know for sure.
Thanks for the interest
Chris
Just clicked and went straight to it? On my ancient iPad, not sure that would be an issue though? Perhaps just search mellens Miata, it should get you there.
