Bond Vinyl hood to glass rear window
The lower edge of the glass rrear window has come adrift fromthe edge of black vinyl hood .
Can anyone suggest an adhesive that will bond the glass to the vinyl material ?
Any help much appreciated!
  1. My model of MX-5 is: __Mk 2 1.6
  2. I’m based near: __Edinburgh
It sounds like you have an after market hood as the metal frame is pressed in on the standard hood ( and BAS hoods)
You need a PU adhesive like tigerseal. Also check the frame doesn’t need lubricating as the hood not dropping properly can cause this.
