Boot lid opening when shouldn’t
  1. My model of MX-5 is: __RF
  2. I’m based near: Stockport
  3. I’m looking for technical help or recommendations on: _Before I have changed to a new battery the boot lid started opening when using the key fob to open the doors and also flipping open again when turning the engine off. The same is still happening now I have
  4. a new battery installed. Can anyone help with a solution please?
Could be moisture in the boot release button on the rear bumper. The contacts can get shorted together so as soon as you unlock the car the boot opens.
Thanks, is there a fix for it?
Replacing the boot release button as a general rule. Depending on how handy you are you may want to see if it comes apart and if so, you could maybe clean/dry it out. To confirm that it is the cause, it’s worth just unplugging it first to see if that fixes the issue.
This 2016 ND Shop Manual | ND Shop Manual is a good place to have a look on how to replace it.
Thank you
Will be a bit Japanese to me. Might have to trust the dealer with it as a last resort but thank you for your help.
Bizarrely righted itself for a day and now has just started flipping open when I turn the engine off?
It is well worth checking a collection of wiring connectors just behind the left hand end of the rear bumper. Over zellous preshure washing underneath can cause a fault here.
Hi Rahul, thanks for your input. The update is Mazda had it in for a week over Christmas and the solution was a rear harness connector replacement with loom, whatever that is!! Total cost of £784 ouch!!
