Boot rack mk3 rht
Which is the best to buy or can I use my old one from my mk1 any ideas thanks
You cannot use any boot rack on a Retractable Hardtop Car
The cover panel bangs into it
There has been a few threads on this subject, have a look at this one: -
http://www.mx5oc.co.uk/forum/yaf_postst44272_boot-luggage-rack.aspx
There are photo’s of the one I converted.
Richard.
Many thanks to both of you will think a bit more before modfieding my old boot rack
Many thanks again William!
The Mazda NC soft top boot rack will fit on the boot of a Roadster Coupe. You have to fit it slightly further back than the instructions say for it to clear the rear cover but it does work, although it does seem to flex the boot skin a bit where it mounts, as the curve of the boot on a soft top is different to that on a Roadster Coupe.
Thanks Roadster Robbie will try that to see if it works
I was referring to a MK3 rack, not your MK1 rack.
Yes did realize you meant the mk3 boot rack
