Hi all, I have a faulty amplifier in a Mk3.5 Sporttec, it is Bose model ku060 serial number nh6166920. I have looked on ebay and the same model appears but with different serial numbers (usually NG20 66920B). Can anyone point me in the right direction to source it or failing that, tell me if the alternate serial number should work?
Cheers
You might consider these people, with a repair guarantee too, well known for NC Bose amp repairs.
Thank you Ian, yes I had seen this company when I looked into it, I was hoping that a straight replacement might be cheaper. I will continue to look and go with the repair if I have no luck.
I have just removed my amp from a 2008 PRHT and was planning on putting it up on eBay. Sorry dont know if it is the right one for your car or not. Pictures attached for serial numbers etc.
Make me an offer if you are interested.
Hi mate, I’m sorry but that doesn’t match my model number. My car is the 2010 Sporttec and I’m informed I have to get a like for like. Thanks for checking with me, good luck on ebay!
