Brake banjo crush washers - where to buy?
For my NC, looking for copper crush washers for the banjo bolt that attaches to the front brake caliper. Had a look on MX5 Parts but they only seem to have them for NA, NB. Euro Parts not showing any for my model.
But I’m guessing these are fairly standard washers that fit other cars? Maybe I could just search for a washer of the required size?
Thanks in advance!
Plenty of copper washers on ebay, do you know the inside and outside diameter of the washer.
If no then order one or more from the Mazda dealer that is a simple idea and even it is dearer than ebay, just get on with it.
If you know the size of the washer just buy them on ebay.
If you post the size of the washer, I will probably have some in my copper washer box and will post you few if I have some matches.
I don’t know the dimensions and would prefer to buy them before taking it apart.
Yes I think simply getting them from Mazda would be easiest.
Thanks for your help and I appreciate the offer to send me some very much.
Give autolink a ring.
Well today on my 32,700 mile 7 year old MK3 the offfside fron caliper went sticky so I will see how far it needs taken apart and if I get as far as taking the caliper off I will post the size here.
15mm OD, 10mm ID.
Thanks for the added advice.
Thickness should be 1mm. They’re available on ebay at just under £3 for 10
http://www.ebay.co.uk/itm/171386288263?_trksid=p2060353.m1438.l2649&var=470433945030&ssPageName=STRK%3AMEBIDX%3AIT
