- My model of MX-5 is: __'07 NC 2.0 Sport
- I’m based near: __Liverpool
Hi all,
What capacity of brake fluid would be required for a full system change ?
Only so I know when I go buying.
Certainly 1 litre. It helps if you remove most of the old fluid from the master cylinder first then you do not have to draw all that old fluid through the system. I use an old trigger spray to remove it.
5l from Eurocarparts is very cheap compared to 1 litre then you would have more than enough. Do you have another car that could do with new fluid?
Thanks Malc, it might be time to refresh me daily driver work van too.
Turkey Baster from Wilco works a treat and cheap. Clean it out and use for the P/S fluid as well.
