Brake hose removal ?
 I’m going to replace my brake hoses with braided lines. I’ve started to take the old ones out but not sure how to get them off ? I’ve removed the brake line above and pulled the clip out but how do i pull the brake hose through the mounting bracket ?
 If you have removed the 10mm union to the hose and pulled the locking clip out, then it should just puul outThumbs up
 Ok - a bit more brute force required !! It just looked like the top part was a lot bigger than the hole it had come out of !!
