Just wondering what the minimum Safari browser requirement is?
I am using 14.1.2 and can’t get the forum page to load properly.
Discourse list requirements at the link below, it is known that older versions of Safari are not supported.
** edited to note that for IOS minimum version supported is 15.7+ **
Thanks Ian. It worked a week ago, I guess I will be installing chrome.
We did install a critical software update in the last week so likely that something in that has taken umbrage at older versions.
Me too. Ageing Samsung tablet stopped working properly - had to get the laptop out instead.
Just to Say as a Mature Chapess…Thanks Chaps For Posting ![]()
[Feel a Little Bit Less of an I.T. Numpty
IanH…If There Was a Prize for Forum Admin/Area Coordinator…You’d Have My Vote…Thank You For All Your Hard Work and Support Across a Multitude of Topics Since I Joined ![]()
With Respect and Gratitude
Android 7 (introduced in 2016) and above supports the current version of Chrome so if within that you should be able to update it.
I have a Ipad IOS 14.4.2 safari, unsupported browser on Forum from last week, so can’t make comments
Installed Chrome, but still the same
Not got issues with any other forums I use
currently on my work computer
Can you try https://try.discourse.org/ from your IOS device and see if you get the same?
A bit more digging shows IOS 15.7+ is required which is quite a recent release (September 2022) so I’m a little surprised on the backward compatibility being quite so aggressive.
