Bulb Recommendations for Mk3
Hi Guys,
Recently got the LED Fog/DRL’s from MX5 Parts and I’m really pleased with them, however they make the other front lights look drab and old by comparison. Does anyone have any recommendations for bulbs that are as white as possible while still being road legal? A lot of the bulbs I’m looking at are being reviewed as not as bright as OEM to the point of being borderline dangerous or being non road legal.
The preferred choice seems to be OSRAM Nightbreakers but they don’t seem to come in a H9 which is what I need for main beam (correct me if I’m wrong)
Any help greatly appreciated,
DT
https://www.ebay.co.uk/itm/Opel-Movano-98-10-F9-H9-J9-U9-E9-Osram-Head-Lamp-Bulb-12V-Night-Breaker/381763523160?fits=Plat_Gen%3AH9&hash=item58e2e11258:g:Qv4AAOSwzLlXhZp7:rk:4:pf:0
Are you sure it’s not the H7 bulb you need?
Quite possibly I’m not fully up to speed on bulb sizes and I’ve not found anything definitive.
https://www.autobulbsdirect.co.uk/mazda-mx5-convertible-2007-07.html
Judging by this I need a set of H7s H9s and 501s? H7s and 501s seem simple enough it’s just the H9s but with the driving I usually do the H9s won’t be on very often so it’s not too bad if they’re a little peachy.
DT
Ring Xenon Ultima do it for me.
I don’t know about colour, but the received wisdom  and my own sometime experience of trying to improve headlamps is to stick with branded ones such as Osram and Philips, and not to go for the brightest end of the range which have a short life.  Compare the claimed lifetime of Osram Nightbreaker Silver (+100%) and Laser  (+150%) versions.  The brightest ones I have tried only lasted months.
I haven’t tried Ring, I think they do OK in this Autoexpress test (ranges have been updated since it was done but it does give clues as to what the variations in performance can be).
Particularly if the lamps are difficult to change, I’d not be too ambitious with the claimed improvement - there’s a clear trade-off between life and brightness.
Thanks for the contributions guys!
From the research I’ve done it seems the it’s seems changing the bulbs in an NC isn’t the easiest thing to do. I’ve discovered these today but I need to do some more digging on the legality of them. As the NC’s lights are projector there shouldn’t be a risk of dazzling other drivers, but they might not fit due to the L shaped fitment.
https://www.boslla.com/
I’ve been using Ring Ultimas in a mix of cars, including two NCs, over many years and never had a problem.
I’ve tried unbranded bulbs in the past and the life has been less than useless. Never had a Ring bulb blow and I’ve also used them on several cars. Had a 56 plate Mazda 6 a few years back. Thought the projector reflectors must be shot because the beam pattern was terrible and output was poor. Swapped to Ring Xenon Ultima and the result was crisp white light with a perfect beam pattern.
What’s the life expectancy like with the Ring Ultimas?
Never had one blow so from my experience somewhere between a long time and forever.
Good to hear as it sounds like replacing them is going to be a pain in the arse!
You bulbs you need size wise are H7 and HB3.
Mine were changed for Osram Nightreaker’s yesterday but I don’t do a huge amount of night driving so the lifespan is less of a concern from my perspective.
