buzzing sound?
 Hello, could anyone tell me why i get a buzzing sound when i turn on the ignition. It will only last a few seconds. It is a H reg eunos. Many thanks in anticipation.
I was told its a seat belt reminder.
EDIT:
I’ve just had a quick look in my Eunos Roadster hand book.
Text below from the hand book.
Seat Belt Reminder Warning Sound:
On ignition should the seat belt of the drivers seat not be used the buzzer will be heard for a few second.
My K reg has an immobiliser fitted that buzzes once it has been initiated and the ignition switched on.
All the while it is buzzing you can start the engine - once it stops you have to go through the initiation sequence again.
Could it be something like that? None of my Mk1s buzz if you don’t have your seatbelt on, just get a light on the dash.
 My MK1 - Lreg (Eunos) has driver seatbelt buzzer & little  light as well. If I start engine with seat belt on it doesn’t buzz, or put it on while it buzzes & it stops.
Hijack!
My car buzzes at me and it’s driving me insane…I’ve only had it a week!!!
It buzzes when the ignition is put on, and then (if the doors are closed) turns off after a few seconds irrespective of whether the seat belts are done up or not. It also buzzes when the doors are opened and the ignition/engine is on.
Please, someone, tell me how I shut it up before I go postal!
Cheers, Rael
If you undo the plug at the bottom of the seatbelt stalk on the tunnel, that will stop the seat belt bussing noise, I also seem to recall from when I imported 5’s from Japan a few year’s ago that there was a single wire plug possibly blue, behind the lower steering wheel cover, that when undone used to stop the bussing ???Shock
I don’t think it’s a seat belt driven buzz, more of a door open warning.
The theory on the other plug, how can I verify this? Don’t particularly want to start randomly removing plugs willy nilly.
 am i the only one who wants my buzzer to work again lol
i wish the buzzer went off when the lights were on, as i just went out to go to the shops and my car was flat with the sidelights on >_< gotta wait till tomorrow to jump it lol fook sake D:
charlie
