- My model of MX-5 is: 2008 NC PRHT
- I’m based near: Yorkshire
- I’m looking for technical help or recommendations on: _ABS Trouble code
Hi all,
I’ve got a weird ABS fault on my Mk3, basically all is fine when driving, until you hit EITHER exactly 60mph or 70mph (its about a 50/50 split between the 2). Once I hit the speed the ABS light flashes on. Stop the car, kill the ignition and start it up again, about 50% of the time the light is off right away, the rest of the time it goes off as soon as I start rolling and doesn’t come back on until I get to the speed again.
I’ve got myself a bluetooth OBD2 scanner and Torque Pro and run a scan, which comes back with code Chassis C1178. According to Torque thats a ‘grey code’ that the ECU clears itself, but when I click for more info it doesn’t have any available. Its entirely possible I’m not looking int the right part of the app though. I’ve had a quick google but all I seem to see relates to Peugeot ECU faults.
Does anyone have any idea what the code relates to?
