Apologies if this appears to be a daft question, but it is a genuine ask. I’m looking to purchase a brake rewind tool in order to ease back the front brake pistons - have an ongoing sticky caliper issue. A Internet search brings options for right and left handed rewind tools. Are both rewind tools required or can either a left or right handed tool be utilised to do the job? Thanks Garry
You can get a complete set for around £20.00 on eBay I bought a complete set and would not be without it now. Used on my sons cars and also great for motorbikes too.
If your going to use pliers or anything else that may damage the pistons I would suggest using a rag under the jaws.
Yes rears only with allen key through the 14mm bolt at rear of caliper ( not the one holding the handbrake bracket 9 the inner one is just blank bolt and has allen key inside ).Fronts just push back with two screwdrivewrs or similar as levers or use winding back tool if you feel happier but DO NOT WIND BACK THE REARS.!!
