- My model of MX-5 is: 2007 ZSport NC 2.0l 6spd
- I’m based near: anglesey
- I’m looking for technical help or recommendations on: identifying cams already installed
Records from previous owner shows the engine had a ‘partial rebuild’ about 6,000 miles ago and at that time was fitted with BBR 4-1 manifold, had a remap at autotronix invoiced as ‘Ecutek remap’… And a bunch of suspension and chassis mods, as you can expect.
I’m considering replacing the cams with something ‘fast road’-ish… But, before I jump at anything, is there any easy way to tell if the ‘partial rebuild’ included a cam swap? I Can pull the cam cover obviously, but would there be any visible markings to indicate stock or aftermarket cams???
Any advice appreciated
