My partner was driving our '96 Eunos when it died very suddenly, no noise or anything. It was towed to a garage of a friend of mine and I had another friend run diagnostics this morning - synopsis as follows:
engine cranks but doesn’t fire (no fuel or spark)
no fault codes present
fuel pump is not priming
power to the PCM
immobiliser appears to be turned off
I am thinking a potential ECU problem or some sort of safety cut-out
Additionally, the drivers side electric window was found to be not working afterwards - whether this is related or not I don’t know…
Hi im not sure if this is any good to you, but i had the same symptoms only last week, today it was diagnosed as the crank sensor, apparently the part is about £60.00, ive no idea what the labour involved is. Good luck, I cant wait to go and collect it and start having some fun again.
Or, thinking about it a bit more, it could be the coil pack. That won’t show a fault code, if it’s dead you’ll get no spark and if there’s no spark the fuel pump won’t run. And it’s a 1.8 mk1 so has the most delicate coil pack.
Had a look at the car this weekend - my friend hadn’t read any fault codes but is not sure he has the correct level of s/w completely. Having not driven the car much I can’t see a MIL light? Is there a MIL light on the Mk1’s? If not, I’m thinking it may be more likely to be CPS than ECU. Removed the ECU at the weekend and no sign of water ingress or high temps.
Jane - when you had your problem did you have any dash warning light?
Neither the UK nor the japanese versions of these cars had the MIL, only the US Miata. Having said that there is a simple way of reading the fault codes, using an LED and a resistor. Info is here:-
