I’m not trying to put you down, but the word ‘parasitic’ is incorrectly used - it means a parasite (a bug)
is present in the car. While the word ‘bug’ is often use to describe faults in computer software, the more correct term is ‘fault’ when applied to electric circuits.
So this invokes a question - Are you checking with the ignition on, or off? If the ignition switch is on, then there will of course be a perceptible drain on the battery. If it’s off, are you checking with a door open? - The normal internal light will be on.
If you have disconnected the Positive lead to the battery, and reading current flow between it and the battery positive terminal, under the following conditions, then the reading you have would either be right, or wrong. One point - if you open the boot to do this, then does your boot light come on, or do you have to switch the parking lights on for it to work? If it comes on without doing this, then you may also read the drain from that light, under any circumstances.
1) Ignition off. Alarm and immobiliser set - these have a constant battery drain under this condition, that is normally around 0.2 amp (200 m/a) The ECU also has a back-up battery, used to retain variable settings, and if that starts losing it’s charge then it will also load the ‘Dark current’. This condition is normal.
Note - Dark current is in fact a misnomer, it actually means internal resistance inside the battery, from which most batteries suffer at some point in their life.This result in an internal current which over time can result in a flat battery.However, the term ‘dark’ is often used to describe the constant external drain on a battery, when apparently, everything is off. This overlooks the fact that when the car is locked and alarmed, the conditions as outlined above are still active.
2) Ignition switch off, alarm and immobiliser deactivated . Boot light on? Car door(s) open? - interior light on. Either of these conditions will show a battery drain current.
3) Ignition switch on, but engine not running - the ECU is ‘live’, so is the ignition circuit, petrol pump etc. Any current drain will be larger than 250 m/a. I don’t know if this will affect the igniter coils on a Mk3, I do know on older cars it can result in a burned out coil if left on for a period of time.
Presumably your comment isn’t about this condition.
Last - Unfortunately I don’t have a wiring manual for a Mk3, so I’m unaware of any potential faults in the door locking circuits, as far as I’m aware they operate on a pulse signal rather that a prolonged one, as you might expect with a motor driven device.* I would suspect a blown fuse, but I can’t point a way to that possibility. Another possibility is you have an earth fault on that circuit, either on the live side, or the negative (earth) connection is open . A live going to earth would show a greater current flow than 250 m/a.- and blow a fuse. On my car (an NBFL) you can still lock the doors with the ignition key, without using the fob, but I’m not sure you can set ‘double locking’ by turning the key twice.- You could on some other cars.
An inactive fob could mean a flat battery inside, but if you can’t lock the doors with the ignition key then I have no idea what the fault might be - without a wiring diagram to look at.
I’ve just checked my NB manual, and the 10 amp ROOM fuse is in the immobiliser circuit, but the power door locking system is on a separate 10 amp fuse marked D.LOCK.- have you got a D.LOCK fuse in the fuse box? If so, is it O/K?
- note (added* I could be wrong on the motor driven device, as my NB manual shows a motor for each power door lock.
However I made this assumption on the fact that there’s no sound of a driving motor, just a ‘clunk’ as the doors lock. On my sones Merc, which also has power door locking, one motor can run for several seconds as that mechanism appears to be in need of attention, though it does eventually lock.
