My centre console has the two round compartments (drink holders?), the middle one (behind the ashtray) has lost the sprung closure action on the lid, with the result that it flips opens under acceleration.
I can see a, rather hard to access, piece of metal on the hinge - presumable some sort of spring - which may have snapped.
Is there any way to fix this - short of replacing the entire centre console?
You do not need to disconnect the Batt for this, there are 5 phillips head screws that hold it down, 2 at the front one under the electric widow switch on the Mk 2.5(under the ashtray on a Mk 2) and 2 at the rear in the armrest cubby hole.
As for the Auto gearshift, there should be a little black slider button at the front, push it back and you should be able the select N without needed to switch the ignition on to do this job,give me a shout if you get stuck.
I used a very thin flexible filling knife 2" 50mm wide. It does need to very thin. Slide it down the rear side and gently lever. hopefully you won’t break the plastic latches that hold the switch block in, I broke one. A slighly narrower blade might be better say 40mm. Best of luck
Had same problem on my 2002 MX5 :-(, If you are lucky like I was its just the end of said lug thats snapped off (lug is only there as something for spring to pivot on & there is a small piece on the end that stops the spring flicking off which had broke on my car). Anyway I fixed it by slotting the spring back on then used an appropriate sized self tapping screw (too big & you will break whats left of lug) with a penny washer to keep spring on. & yes the electric window switches were tight! I used some thin plastic trim removal tools but 2 small screw drivers will do it but you will have to be very careful with them so as not to damage anything.
