Changing rear anti roll bar drop links NC
hi Guys
Just had the NC serviced and warned of slight play in the rear near side drop link.
I know this is a common MOT failure.
How difficult are these to change? I know it two nuts. Probably tapered joints. do you need to place them under any tension etc.
Cannot see anything under FAQ.
Any advice appreciated?
Mike
Tricky part is getting the rusty nuts off Mike as the pin’s not tapered and spins. There’s a hex (5mm?) key socket in the end to hold it when putting the nyloc on but it’s not much good a few years later when the thread’s rusty. Some grind them off but I found I could grab the flange of the pin (see pic) by clamping with narrow jawed vice grips on the boot side and the nuts came off fine. This one is Mazda 6 front, rear lower mounting looks tight on space so check first. No real tension there but use a jack to adjust if needed. If you do take off both sides be sure the links end up vertical (see pic) as the bar can drop and they can be put on over-centred otherwise.
Once again thanks for a detailed reply Rich
Must say the underneath of your car looks great, presumably dinotrolled.  Was this a DIY job or did you get it treated somewhere?
Mike
if your changing em you could get an RX8 rear ARB and fit that at the same time.
Thicker and stronger for less boddy roll. and cheap too.
Alan
Thanks Mike, yes, pro job by Chassis Clean and well pleased with it, after 2 years light use it looks pretty much the same :slight_smile:
 There is a ‘How to do’ guide by Roadster Robbie in the downloads section.  It shows how to remove the nut when the heagon in the end of the threaded part rounds out.
Regards Geoff Peace.
Excellent thanks Geoff (and Robbie!) I didn’t need to go that far with mine but it’s useful to know the joint will come apart. I wonder if that’s only the Mazda one though and if others are constructed differently? Certainly don’t rely on the hex key for other than fitting the new one, still got to fix mine from that job!
 Personally I favour a hacksaw cut down one side of the nut, most nuts surrender under such a threat.  Your hexagon bit looks quite ill!  I was about to say buy Britool, but I am told they have gone downhill of late.
Ha ha yes Britool may be better but I only buy the best you know Geoff, made in China I think it says, but I suppose something will either bend or snap when subject to such abuse… Halfords replaced the 14mm ratchet ring I used on the nut… still, this has a replaceable hex so I will go cut another one… :slight_smile:
Made in China, obviously top notch then Rich.  All you need now is a left hand thread to straighten it!
