Cheap adjustable coilovers...
I found these cheap coilover spring things on ebay… They fit on the standard shocks, but are very cheap probs abit too good to be true!
Has anyone ever used these or know if they’re worth buying?
http://cgi.ebay.co.uk/89-02-Mazda-MX5-Miata-Eunos-Lowering-Springs-Coilovers_W0QQitemZ160312693844QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item160312693844&_trksid=p3286.c0.m14&_trkparms=72%3A1689|66%3A2|65%3A12|39%3A1|240%3A1318
Cheap, good, pick either[;)]
They might be superb and then again they might be total rubbish. Don’t think I’d trust my life to them and perhaps it might be a better idea to save up and get properly designed components from a recognized manufacturer?
Knowing my luck, you will probably buy them, fit them and drive rings round me at some trackday [:S]
Junk. Don’t buy.
Ask the seller if he knows the spring rates. Rears need to be 55-60% of the fronts
Chances are the rear springs will be outrageously stiff (same as fronts), leading to bad oversteer.
Yeah i guessed they would be total poop!
Think i’m going to just stick to plan A and buy some trim springs then upgrade the shockers at a later date!
Thanks for the info though! =D
