Wondering the best way to access the Clutch bleed point without having the car on a lift ?
Logic says to me to jack up and go via the drivers side wheel arch but but having not looked for it before I hoped some one here would give me a few pointers before I get out there in the cold to tackle it !
Many thanks in advance
Passenger side front at the minimum needs to be jacked up and supported. Easiest to do if you completely remove the underbody cover to access the slave. Manually bleeding I found to be a little more problematic, but very simple with an eazibleed.
Many thanks. I’ve a pressure bleeder so usually on other cars I uses a combination of that and the usual pedal pushing etc.
If it’s an NA or NB then it can be accessed through the driver’s side front wheel arch.
Sorry. I thought I’d mentioned NC but obviously haven’t !
