Clutch pedal extender
Hi! Has anyone extended the clutch pedal ? If so what with and how?
The other pedals are fine but I have to sit uncomfortably close to the steering wheel, and the clutch likes to bite virtually at the floor.
Not done this before but if there were a requirement as in your case, would probably fit some sore of raised block to the pedal face.
I would imagine this could be achieved reasonably easily.
I think I would check the system over? Fluid leaks possible? Slave cylinder can become fubar’d, replacements are not expensive. Check fluid is up to level under bonnet. Search pedal adjustment too, a bit awkward as its under dash but it is doable. Is it difficult to engage gears at all?
I would mirror the above advice
I would be very cautious modifying pedals yourself too get round your problem as if something where too happen out on the road and you were to be involved in an incident I’m sure the insurance or even the police would be delighted to see a diy pedal mod .
Good point Paul but better of with a modified pedal than a modified shoe:-)
As an aside why do you add ‘o’ to the word to - it’s too much buddy:-)
You can never have enough to too or twos in your life ??
I would agree, the pedal can be adjusted (slightly) to better the change. When I adjusted mine it certainly improved things as it was necessary to floor the pedal to get a smooth change, just a slight tweak made all the difference, it’s a bit awkward to get at, contortionist springs to mind.
Thanks for replies. Seen some makeshift extensions online. I think I’ll try to get it adjusted first. Anyone know a good garage in Poole, Dorset area?
Cheers
Carol
They are available here
Thanks, I am looking into this option.
