Hi,
I’ve got a 2003 Mk2.5 MX5 and want to test the fuel pump.
In earlier versions of the MX5 there is a diagnostics box in the engine compartment that can be used to test things and get engine fault codes.
In the Mk2.5 there is an EOBD connector in the driver’s footwell which is presumably now used to get fault codes.
However, there is also a grey box in the engine compartment called DIAGNOSIS.
Does anyone know what this is actually used for? Can it still be used to get fault codes and can I still use it to test the fuel pump (by connecting the GND and F/P terminals)?
Many thanks
