As bally says easy enough if you have a few spanners, fiddly to gaining access, getting the throttle body off etc
The water pump is at the front obviously where the auxiliary belt is, the stat on the side under the throttle body, inlet side.
Whilst there change the coolant if its not been done, FL22 is the stuff, has a 10 year lifespan so check up if you’ve had yours done recently. Needs a few flushes to get the old out, use deionised water to flush.
This one is a pretty reasonable price from Autolink, a respected supplier of parts for our cars, use them often…
Cheap ones through to a Mazda expensive one.
Loads of different ones out there and actually quite difficult to decide.
I have just bought this mid range one with 3 year warranty.
Got it a bit cheaper off the same company on eBay with one of the deals.
