Hi Michael. It sounds as if it might be alright. It may be possible to very lightly polish the scarred area with very fine emery cloth to get rid of any burs around the scarring. Have you got a micrometer to check the diameter of the affected crank journal and compare it with the others or check whether it is within manufacturing tolerances? If polishing does not recover the situation you could have the crank reground (all journals if high mileage and fit oversize (undersized diameter really) crank bearings or even buy a new crank.
I will have a look and measure it, I did rub my finger across the marked area and I couldn’t feel any thing at all, still felt smooth, I will check and keep my fingers crossed. Just trying to keep my little car on the road.
As I’m at work on my own watching Goodwood and looking on here I thought I would look up the crank sizes for you as I work in an engineering company than regrind cranks as one of our services.
According to the ACL bearing catalogue the big end journals should measure between 46.980mm - 47.00mm or if you are measuring in old money then it is 1.8496" - 1.8504", so those sizes are the upper and lower limits for the standard bearings and obviously they should be round. I hope that helps you.
Chris.
