- My model of MX-5 is: mk2.5_
- I’m based near: Southend Essex
Engine was cutting out at higher revs after being driven for a while, I removed a cupful of debris from the tank then hoovered the remains the next day, the pick up filter was cleaned with a nail brush and washing up liquid, car now runs superbly no hint of a problem. The car had stood unused for 10 years so it’s no surprise really, and the inside of the tank that’s visible looks pretty good. If anyone is interested I will give more details on here.
Dave
Its good when you get a result!
Never a truer word spoken, thank you.
Regards Dave.
How did you remove the tank crud?
Drove till very little fuel left, removed 5 parcel shelf carpet trim fir trees and rolled trim back to under rear window, remove inspection plate (large one with 6 screws) remove electrical connector remove 2 fuel pipes, take out 8 screws and lift out fuel pump / float etc. I then used a glass thoroughly cleaned and de labeled Doritos salsa jar to remove most of remaining fuel then a spray can lid to scoop out last dregs and a lot of the crud, then used finger tips then rags, once bottom of tank was empty but still damp with petrol I left it overnight after having removed virtually all the crud with rags I then next day hoovered out the dry powdery debris after using a small Allen key to move the bits hiding under the baffle plate, I had also got my arm as far as possible into the tank and rubbed as many surfaces as I could and brushed the debris to the tanks low point where the fuel pick up resides so I could pick/hoover it out
All in all a bit of a ball aching but satisfying job with a sense of achievement and plenty of folding stuff saved . Sorry for the long boring reply but hope it may be of use to someone, Any other questions please ask.
Dave
Ah Ha!
Did not know about inspection plate.
Good lad!
it’s the large plate more or less central.
Hi all, a bit of an update on this problem, it returned after a while when petrol was getting low so I am doing the job again drove around till near enough empty 1.25l came out of the tank, not so murky and way less debris than before but enough to cause a problem, I have nearly finished the job jus got to hoover out the remaining powdered rust then I will try to get the last residual out with an oily rag, last time I only put around £30 quids worth of fuel in so there maybe some more debris higher in the tank to be dislodged when I fill it fully up, so I guess I may be doing this once or twice more hey ho I guess it’s better than hanging around street corners getting into trouble . Dave
