Hi, A week or so ago I had a bit of a moment in my NB and ended on the grass verge on the wrong side of the road managing to scrub off the two passenger side tyres in the process. Looking at the passenger front wheel it appeared to have a lot of toe-out and on removing it to see what damage had been done it is obvious that I have bent the suspension backwards with the shock no longer sitting in the middle of the hole in the upper control arm (photo attached).
Advice please; What have I managed to bend? What do I need to do to fix it?
Cheers Dave
Upper wishbone bolt not sitting horizontal. Bigger gap on front end to rear. Start there.
Remove the other wheel and if it looks straight on the suspension it will give you fair idea by comparing the two.
On the driver’s side, the shock goes through the centre of the hole in the control arm so I’ve definitely bent something on the passenger side.
Just trying to work out what is bent and how to fix it.
I’d focus more on the lower arm, that’ll have taken the brunt of the impact I’d guess.
The upper arm long bolts are angled by design.
